limpy88 Posted August 21, 2018 Share Posted August 21, 2018 Well after my failed trip, I have come to realize the stock screen is useless. Also would like some handle bar risers. Thinking the helibars just cause color match, but will see. Since the factory hand guards are so big. If the were up higher would the interfer with the large aftermarket screens that have cut outs for the guards? Or will it no be an issue? Wondering if anybody has experience with this? Link to comment Share on other sites More sharing options...
koth442 Posted August 22, 2018 Share Posted August 22, 2018 Personally I'm very fond of CalSci windshields. However bar risers may result in contact at full lock. Since there are hand guards you don't have worry about pinching your fingers and accidentally applying the brake. And how often do you really go to full lock anyway? '15 FJ09 Link to comment Share on other sites More sharing options...
limpy88 Posted August 22, 2018 Author Share Posted August 22, 2018 And how often do you really go to full lock anyway? Only in the garage to move it around really. Link to comment Share on other sites More sharing options...
nhchris Posted August 22, 2018 Share Posted August 22, 2018 ... If the were up higher would the interfer with the large aftermarket screens that have cut outs for the guards? Or will it no be an issue? Wondering if anybody has experience with this?I have a Parabellum 26" screen on my 2016 09 and it has cutouts for the hand guards that fit perfectly with stock bar location / height. Lock-to-lock steering is no problem. In looking at this screen I would guess that installing a riser for the bars would foul up the fit and reduce the steering arc. cb 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
limpy88 Posted August 22, 2018 Author Share Posted August 22, 2018 Thanks. That is the answer I was looking for. Link to comment Share on other sites More sharing options...
Panther6834 Posted August 24, 2018 Share Posted August 24, 2018 I have the Puig Touring Windscreen installed, using the includes handguard brackets (they move the second piece of the handguard figure out by approx 1.25"), as well as the SW-MOTECH Barback Risers. I've had no problems, whatsoever. However, when it came to installing the barback risers, I discovered a "problem" (which had nothing to do with the windscreen, or (technically) the risers) - the brake & clutch cable lengths don't allow for excessive movement of the bars. Thankfully, the "resolution" was quite simple. When installing the SW-MOTECH Barback Risers, if the OEM risers remain in the 'stock' position, it moves the bar back too far, resulting in the brake & clutch lines begging stretched too far. A lot of people don't realize that the OEM risers have 2 positions: back, & forward. The "stock" position, as placed by most dealerships, is in the 'back' position. However, if you remove the bar, loosen the bolts holding the OEM risers, rotate the risers 180°, place the bar back into the OEM risers, and then tighten the riser bolts, this will allow the barback risers to be installed without stretching the brake & clutch lines. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 24, 2018 Supporting Member Share Posted August 24, 2018 A lot of people don't realize that the OEM risers have 2 positions: back, & forward. The "stock" position, as placed by most dealerships, is in the 'back' position. However, if you remove the bar, loosen the bolts holding the OEM risers, rotate the risers 180°, place the bar back into the OEM risers, and then tighten the riser bolts, this will allow the barback risers to be installed without stretching the brake & clutch lines. That's exactly how I have my risers and Helibars bar back set up. I have also had the risers facing back with the Helibars riser for over a year and didn't have any issues with any of the cables. The brake cable has a mount bolted to the bottom of the triple clamp that can be undone to give you an extra 1-1.5" or so of slack. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
limpy88 Posted August 25, 2018 Author Share Posted August 25, 2018 I installed my helibars risers. Got a givi d2122s on order. Will see when it arrives. I did remove the factory hand guards. It helped with wind buffeting. Probably not install hand guards till the screen comes in and i can measure for new ones. Link to comment Share on other sites More sharing options...
JP3RKS Posted May 8 Share Posted May 8 I ordered the SW Motech risers. Does someone have a link to the thread or pictures of installation and avoiding cable stretching? Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 8 Supporting Member Share Posted May 8 I put these SW-Motechs on my 2015 a few years ago and have them up as high as they will go and as far back as they will go. I recall at the time I thought I'd have trouble with my cables but all was (mostly) well and there were no problems created with throttle or clutch cables at both locks but my front brake line was at it's limits. While I had no problem with it I did end up changing my brake lines out some time later for braided lines but that wasn't the reason they were done. Installation instructions will come with them that are clear (I assume they are new) and are straight forward. Hope this info is of some help. 🙂 P.S. I had removed my handguards from day one so if you still have yours there may be a possible issue with interference with your screen. I'm not certain about this and YMMV but thought I should mention it. Some pics... Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 8 Premium Member Share Posted May 8 I presume my Renthal Street Naked bars with OE risers set rearward give me about the same or more rise and setback as your SW-Mototech risers and OE bars but with more (comfortable) sweep. Clutch, throttle and brake lines are not an issue though I may have intrinsically rerouted them. My KTM handguards do not impinge on any of my 3 aftermarket screens including the barn door Givi Tour. Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 9 Supporting Member Share Posted May 9 14 hours ago, 2and3cylinders said: I presume my Renthal Street Naked bars with OE risers set rearward give me about the same or more rise and setback as your SW-Mototech risers and OE bars but with more (comfortable) sweep. You mean the Renthal Street Naked bar (819-50) that I too have fitted along with the SW-Motechs since my photo was taken giving me an even more-more (comfortable) sweep? 😉 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 9 Premium Member Share Posted May 9 Nice! I thought about black but stayed silver but cut 13 mm off each end and drilled n tapped for the oe inserts for the KTM handguards. The clamps do fit right on the rise bit of bar. Packed full n solid with BBs + bar end r&g sliders. I'm not sure I could tuck with more rise and setback. After all I'm still married to my fastest red 98 VTR Firestorm! 1 Link to comment Share on other sites More sharing options...
