2linby Posted January 26, 2019 Share Posted January 26, 2019 Who uses them? For DRL's or actual night light use? I' have a set of cheap bay lights 10W LED's and am looking for more/better lighting without breaking the bank. Those Denali's look good but $275.00 is a deal breaker. Thanks! Everything is simple, Nothing is easy Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 26, 2019 Supporting Member Share Posted January 26, 2019 There should be plenty of archived post with write ups and photos, try a search, its been discussed many times. A lot of different LED lights and mounting options. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
jdavis Posted January 27, 2019 Share Posted January 27, 2019 I put cheap eBay DRL on my 15 to light up immediately in front of the bike at night. Mainly for driveways. Write up on here somewhere. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted January 29, 2019 Premium Member Share Posted January 29, 2019 I've been running the cheap EBay lights for a couple of years now. They work well. Let’s go Brandon Link to comment Share on other sites More sharing options...
2linby Posted January 30, 2019 Author Share Posted January 30, 2019 8 hours ago, micah2074 said: I've been running the cheap EBay lights for a couple of years now. They work well. I have the same and they just don't put out the light that I had hoped for. As DRL's they are fine, but not enough to actually put usable light on the road. Hoping someone has used something that doesn't break the bank. Everything is simple, Nothing is easy Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted January 30, 2019 Premium Member Share Posted January 30, 2019 That’s strange mine are quite bright. Let’s go Brandon Link to comment Share on other sites More sharing options...
jdavis Posted January 30, 2019 Share Posted January 30, 2019 I use eBay 90 watt spotties for distance, hardwired into the high beam. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted January 30, 2019 Premium Member Share Posted January 30, 2019 Nilight 2PCS 3 Inch Square 18W Spot LED Work Lights, 2 years Warranty – Nilight Led Light WWW.NILIGHT.COM UPC: 595223066105 Specifications: LED Power: 18 W (6 x 3W LED) Beam: Spot Beam Lumens: 1260 LM Voltage: 9-30V DC Waterproof Rate: IP67 LED... Bright enough that on-coming traffic flashes me if I'm not very careful aiming them down and to the right a bit. IMO they more than adequately light up the road at posted limits up to 65 MPH at night. Sometimes wattage and lumens don't tell the whole story. Their color temperature is about perfect and beam angle (spread) and uniformity is near optimum; especially for their price point. These are the adapter mounts that I used to bolt the driving light brackets to the Givi case guards; I did not use the "L-brackets"), I just bolted the DL brackets to the piece that clamps to the 23 mm Givi case guard tubes. Amazon.com: Partol Tube Clamps Mounting Brackets 1" Aluminum Adjustable Bull Bar Suitable for Most Straight or Curved LED Work Lights Off Road Light: Automotive WWW.AMAZON.COM Buy Partol Tube Clamps Mounting Brackets 1" Aluminum Adjustable Bull Bar Suitable for Most Straight or Curved LED Work Lights Off... Link to comment Share on other sites More sharing options...
snowgoer Posted March 16, 2019 Share Posted March 16, 2019 On 1/30/2019 at 4:23 AM, jdavis said: I use eBay 90 watt spotties for distance, hardwired into the high beam. Nice set up Link to comment Share on other sites More sharing options...
