This topic contains 21 posts. A summary containing the most significant posts is available
Featured Replies
Posted
Hi, just bought an awesome Tracer 900. Love it!
Stupidly tried to plug in air compressor and now cigarette lighter not working.
People online suggest replacing Terminal 1 fuse, manual says this is under the seat. I looked and there are two banks of fuses that are obvious and 2 sealed modules. These two sealed modules are what the manual suggest holds the terminal 1 fuse that should be blown.
Any ideas? I know there is a front fuse box, but I can't see it. Please don't tell me I need to strip down the whole front end!!! :(
Thanks in advance,
Ryan (newbie member, so apologise if it's been posted before)
You'll need to remove the front rhs fairing to access two fuse blocks, but that's an easy job as it's secured by three 'quick-fastener' screws which come out (and go back in) very quickly and easily.   The manual has pix somewhere.   God alone know why the various fuses are scattered all over this bike!
Edited by wordsmith
  • Author
wordsmith - you Sir, are an absolute gent!
Thanks so much! You've just saved me a whole lot of running around!!! Fuse located, new 3A fuse ordered!
Don't you just love it when a forum works???
Happy riding :)
Ry
I installed a pigtail directly to the battery that can be used to power a compressor, battery tender or accessories. I've used the cig lighter just for charging my phone.
I have an optimate lead to battery and plug compressor into that, learnt a while ago that accessory plugs don't like compressor' s!
Edited by nigel5
1 hour ago, nigel5 said:
I have an intimate lead to battery and plug compressor into that, learnt a while ago that accessory plugs don't like compressor' s!
Same here: battery direct for pump/ compressor.   Behind-screen leads for 12v voltmeter and 2 x DRL LEDs.
  • Author
So no need for a fuse if running straight from battery?
I don't have one, others may, but an in-line fuse costing about $5 may not be a bad idea!
 If you use a battery tender lead they are already fused, usually 7.5amps. If you make up your own wiring make sure you use a fuse, those wires will be hot all the time.
I purchased mine at cycle gear. Takes less than 5 minutes to install.
This... $1.75.
Standard Duty 5A 3AG Inline Fuse Holder
  • Author
Is it worth fitting an on/off rocker switch on the positive so the lead doesn't stay constantly 'hot'?
I'm thinking of keeping this outlet under the passenger seat, out of the way, and for use in emergencies anyway, therefore, won't be used that often.
Thanks for all your input chaps.
Ry
Ry
If it's only purpose is the compressor you could just get rid of the compressor's male cig connector and replace with battery clamps or use a female cig-to-clamp adapter which are available on Amazon and most auto parts stores.
  • Author
That would make life a lot easier! Had no idea an adapter like that even exists! So, thanks to this thread, I’ve managed to solve my original problem AND sorted the compressor issue through a simple adapter! That way I can still use it on my car through the conventional cig socket! Thanks all. Ride on ;)
  • Community Expert
Ry
Look for a compressor that has an SAE connector, same as your battery tender.  My battery tender lead is connected to my battery permanently, when I'm not riding over the winter, I plug in the tender, my heated vest also uses an SAE plug - very convenient.
Important Information
