Supporting Member betoney Posted December 26, 2019 Supporting Member Share Posted December 26, 2019 (edited) I recently replaced my brake lines with braided lines, ABS pump was not unplugged or removed from the bike. One line replaced at a time. The brakes work fine but today I decided to try the ABS function on damp pavement. I pressed firmly on the rear pedal and it pulsed 2-3 times like normal and then locked up into a skid. I decided to check the front so I rode through some loose gravel slowly and grabbed the brake lever, again, pulses 2-3 times and skids to a stop. I checked it many times and could not get ABS to gradually slow the bike, the ABS light comes on and I have to cycle the key on/off to clear the warning light but the ABS light only comes on during the skid, not under normal riding. Both pedal and lever feel firm (proper bleed, not spongy) and the brakes work normally until the ABS module activates, there are no error codes on the screen. Any thoughts or experience with ABS issues? Edited December 27, 2019 by betoney ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
koth442 Posted December 27, 2019 Share Posted December 27, 2019 Interesting. I've not heard of this issue before. I'm curious what others have to say. '15 FJ09 Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted December 27, 2019 Supporting Member Share Posted December 27, 2019 For what it's worth I just finished the lines on my 19 GT, the lever- petal feel great but the ABS is not acting right but no ABS light. From what I have been able to determine the dealer needs to cycle the ABS pump with his dealer only tool to flush the system and reset the system. This is not coming from the dealer but from what I have read on the world wide web "so it must be true". I'm taking my bike by the dealer tomorrow to so what they have to say, I'll let you now tomorrow👍 2 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 27, 2019 Author Supporting Member Share Posted December 27, 2019 4 minutes ago, roadrash83 said: For what it's worth I just finished the lines on my 19 GT, the lever- petal feel great but the ABS is not acting right but no ABS light. From what I have been able to determine the dealer needs to cycle the ABS pump with his dealer only tool to flush the system and reset the system. This is not coming from the dealer but from what I have read on the world wide web "so it must be true". I'm taking my bike by the dealer tomorrow to so what they have to say, I'll let you now tomorrow👍 Thanks for the info. I was thinking along those same lines. I'll be interested to hear what your mechanic finds. 👍😎 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted December 27, 2019 Supporting Member Share Posted December 27, 2019 Following with great interest. I’ll be installing my new Galfer lines in the next couple of weeks, so anxious to hear if there is an additional step in the process 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 27, 2019 Author Supporting Member Share Posted December 27, 2019 59 minutes ago, texscottyd said: Following with great interest. I’ll be installing my new Galfer lines in the next couple of weeks, so anxious to hear if there is an additional step in the process Yeah, I'm hoping its something simple because it sure doesn't make any sense to me. The only thing that changed on the ABS pump itself was removing and replacing 4 banjo bolts, the pump remained full of brake fluid. I might have to see if I can make it to the dealer to get it checked tomorrow or Saturday like @roadrash83 suggested. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
BBB Posted December 27, 2019 Share Posted December 27, 2019 I’ve had this type of problem with older cars, so it may have some relevance here. Now that you’ve cycled the ABS pump, try bleeding each line again. You may have freed bubbles that had accumulated in the ABS pump. 1 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 27, 2019 Author Supporting Member Share Posted December 27, 2019 35 minutes ago, BBB said: Now that you’ve cycled the ABS pump, try bleeding each line again. You may have freed bubbles that had accumulated in the ABS pump. I will give that a try, thanks. 👍 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
chitown Posted December 27, 2019 Share Posted December 27, 2019 (edited) 14 hours ago, roadrash83 said: For what it's worth I just finished the lines on my 19 GT, the lever- petal feel great but the ABS is not acting right but no ABS light. From what I have been able to determine the dealer needs to cycle the ABS pump with his dealer only tool to flush the system and reset the system. This is not coming from the dealer but from what I have read on the world wide web "so it must be true". I'm taking my bike by the dealer tomorrow to so what they have to say, I'll let you now tomorrow👍 Don't know about the GT but the shop manual for an FJ-09 doesn't call for any such procedure to flush or reset anything. Have heard other motorcycles with ABS have such a thing but none of my Yamahas with ABS call for it in the shop manuals ('15 FJ09, '05 FJR 1300). The only item different for the FJ-09 from bleeding any old system is that the manual specifies an order, bleeding front first then rear. There is a "hydraulic unit operation test" that requires a diagnostic tool that is to be performed AFTER bleeding. Have bled my system a few times, including at brake line replacement, and never did the test nor experienced any problems. Of course, now that someone has had problems that test might prove useful. Edited December 27, 2019 by chitown typo Link to comment Share on other sites More sharing options...
skipperT Posted December 27, 2019 Share Posted December 27, 2019 Great suggestion @BBB. Now that the inner workings of the abs unit have been activated, some air may have been pushed into the lines where it can easily be bled out the main 3 calipers. the service manual details a way to pull codes @betoney - but I wouldn’t worry about that yet unless you’re curious. They can be read and cleared similar to being in DIAG mode once the abs coupler has been jumped IIRC. Full bleed and another test ride should fix it. Keep us posted, -Skip 1 Link to comment Share on other sites More sharing options...
Premium Member coachluciano Posted December 27, 2019 Premium Member Share Posted December 27, 2019 1 hour ago, betoney said: I will give that a try, thanks. 👍 I was kinda thinking that too, but didn’t have any knowledge to base it on 2015 FJ-09 - Andreani Cartridges, Ohlins 535 Rear Shock, LightTech Chain Adjusters, Yoshi Fender Eliminator, Blaster-X Integrated Tail Light/Blinkers, Full Yoshi Exhaust, Ivan's Flash, Bagster Seat, Rizoma: (Bar, Grips, Bar Ends, Mirrors, Oil Cap, Rear Pegs) Bremob Corsa Corta Master Cylinder, Bremob RCS19 Hadraulic Clutch, GPR Steering Damper, Speigler Hydraulic Lines, EBC Brake Pads, Puig Screen, HealTech Quick Shifter, MPG Rearset, XSR900 Slipper Clutch, Driven Racing Halo Gas Cap, SW-Motch Front / Rear Axel Sliders, R1 Rotors / 320mm Kit Conversion. Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted December 27, 2019 Supporting Member Share Posted December 27, 2019 @betoney and @texscottyd I took the bike up to the dealer this morning and had them flush and activate the ABS pump with their scan tool. the brake petal and lever feel great, the ABS works as it should. They said you need the tool to properly bleed and flush out the ABS. The Tracer is not like the older Yamaha that you can jump the wires to activate the pump. Total cost was $112.00😢 1 2 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 27, 2019 Author Supporting Member Share Posted December 27, 2019 3 minutes ago, roadrash83 said: @betoney and @texscottyd I took the bike up to the dealer this morning and had them flush and activate the ABS pump with their scan tool. the brake petal and lever feel great, the ABS works as it should. They said you need the tool to properly bleed and flush out the ABS. The Tracer is not like the older Yamaha that you can jump the wires to activate the pump. Total cost was $112.00😢 Thanks for the info, glad to hear that it is working properly now. Did they give any indication as to why this happened? Surely it shouldn't be "required" as part of replacing the brake lines? I guess I will get the bike to the dealer in the near future. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted December 27, 2019 Supporting Member Share Posted December 27, 2019 Very interesting... much appreciated information, @roadrash83. With mine being a 2015 FJ, I wonder if the process is the same? I’m have a factory service manual, so will dig into it and see what I find. The brakes on mine feel kind of wooden right now (even with the big rotors and HH pads), so I’m anxious to get the lines installed & fresh fluid through the system. Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted December 27, 2019 Supporting Member Share Posted December 27, 2019 1 hour ago, betoney said: Thanks for the info, glad to hear that it is working properly now. Did they give any indication as to why this happened? Surely it shouldn't be "required" as part of replacing the brake lines? I guess I will get the bike to the dealer in the near future. @betoney When the brake system was opened up to replace the lines air gets into the system, specifically the ABS unit so the unit must be bleed. When you are just flushing as part of routine maintenance you flush the brakes then get ABS to activate, then flush the system again to remove the old fluid that came out of the ABS pump by flushing the system again ( no air entered the system). The tech at the dealer ship said be glad you don't have an MV they call for purging the system 5 time for a fluid flush. 1 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
