brewhaha Posted August 21, 2020 Share Posted August 21, 2020 I remember a long time ago reading there were some tricks to getting it to work. I've never needed mine but it would be useful. My 2015 plug doesn't seem to work. Thanks in advance! Link to comment Share on other sites More sharing options...
andz Posted August 21, 2020 Share Posted August 21, 2020 After reading this I realised I have never used mine. I went out to the garage, plugged in my cell phone charger, turned the key and it works. No tricks required. 1 Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted August 21, 2020 Supporting Member Share Posted August 21, 2020 As mentioned, it’s switched power that comes on with the key. Otherwise it should just be plug in & go. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 21, 2020 Supporting Member Share Posted August 21, 2020 1 hour ago, brewhaha said: I remember a long time ago reading there were some tricks to getting it to work. I've never needed mine but it would be useful. My 2015 plug doesn't seem to work. Thanks in advance! It 'should' be connected from the factory, but it could also have malfunctioned or blown a fuse. Mine started working intermittently and I had it replaced under warranty. Easiest process would be check the fuses first, behind the right side panel. Next step would be verify 12v at the plug itself w/ key on. If you don't want the cigarette lighter style power outlet, you can replace it with a USB socket. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
HGP61 Posted August 21, 2020 Share Posted August 21, 2020 It's protected by a 2amp fuse, I blew the fuse first time I tried to use it. 1 Link to comment Share on other sites More sharing options...
brewhaha Posted August 21, 2020 Author Share Posted August 21, 2020 ok, let me check the fuse. Link to comment Share on other sites More sharing options...
Waldo Jeffers Posted January 8, 2021 Share Posted January 8, 2021 Hi there. Was it the fuse? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 8, 2021 Supporting Member Share Posted January 8, 2021 10 minutes ago, Waldo Jeffers said: Hi there. Was it the fuse? Behind the right side panel. https://www.tracer900.net/topic/2977-fuse-location/ 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Waldo Jeffers Posted January 8, 2021 Share Posted January 8, 2021 Thanks bud! 1 Link to comment Share on other sites More sharing options...
