Premium Member alejandro Posted July 6, 2018 Premium Member Share Posted July 6, 2018 Do you even have an FJ-09? Wait, so being frustrated when a bike wants to wheelie under full throttle in 1st and 2nd gear is specific to the Fj-09? And here I thought that would happen with most motorcycles. Silly me. The FJ's geometry and weight bias mean that the front end gets light quite easily. I figured that the (new) GT's longer wheelbase might help tame that. That's why I asked. Link to comment Share on other sites More sharing options...
Premium Member alejandro Posted July 6, 2018 Premium Member Share Posted July 6, 2018 Wait, so being frustrated when a bike wants to wheelie under full throttle in 1st and 2nd gear is specific to the Fj-09? And here I thought that would happen with most motorcycles. Silly me. The FJ's geometry and weight bias mean that the front end gets light quite easily. I figured that the (new) GT's longer wheelbase might help tame that. That's why I asked. (It gets even more wooly with a passenger.) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 7, 2018 Supporting Member Share Posted July 7, 2018 The FJ's geometry and weight bias mean that the front end gets light quite easily. I figured that the (new) GT's longer wheelbase might help tame that. That's why I asked. You could also try a 43T sprocket on the rear, or add a link to the chain to adjust it further back. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member alejandro Posted July 7, 2018 Premium Member Share Posted July 7, 2018 The FJ's geometry and weight bias mean that the front end gets light quite easily. I figured that the (new) GT's longer wheelbase might help tame that. That's why I asked. You could also try a 43T sprocket on the rear, or add a link to the chain to adjust it further back. Adjusting it further back is a interesting idea. I’ve thought about lowering the front a bit in the triple tree, too, or rotating the bars forwards and down. Link to comment Share on other sites More sharing options...
norcal616 Posted July 7, 2018 Share Posted July 7, 2018 Yamaha prefers a slight rear weight bias on its motorcycles... 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
Premium Member alejandro Posted July 7, 2018 Premium Member Share Posted July 7, 2018 apparently... Link to comment Share on other sites More sharing options...
ayrton Posted July 9, 2018 Share Posted July 9, 2018 Thanks for the great suggestions. Link to comment Share on other sites More sharing options...
pattonme Posted July 10, 2018 Share Posted July 10, 2018 Yamaha prefers a slight rear weight bias on its motorcycles... and yet the supersports go the other way and IMO the FZ/FJ could benefit from 50/50 or 51/49. Link to comment Share on other sites More sharing options...
johnsf Posted July 25, 2018 Share Posted July 25, 2018 I’ve also added my Garmin Zumo 395. Power hook up was easy using accessory plugs behind the screen, and ram mount in centre of bars fiits nicely without obscuring the display which I like a lot. hi Vic - another UK member with 900 GT I'm looking to connect GPS to auxiliary socket. When I removed the screen there was a plate behind with 4 screws. Done up so tight I was worried about stripping the allen key! I gave up but will try again this weekend. What connector did you use to plug into harness? Link to comment Share on other sites More sharing options...
vic Posted July 26, 2018 Share Posted July 26, 2018 Hi John If you remove that plate (and it did take some effort. I used a socket wrench with Allen key socket), behind it you will find a rubber boot with various connectors in it. One of the (gray as I recall) has a blank male connector. Remove this and you can connect the Garmin here. You will need the pins to fit in to the male plug, and make sure you connect it the right way round, as polarity isn’t obvious. The connector is a male MT090 available on Ebay https://www.ebay.co.uk/itm/2-x-MT090-2-Pin-Auxiliary-male-power-connector-Yamaha-MT09-Tracer-MT07-Aux-Plug/202360040706?hash=item2f1d992d02:g:AL8AAOSw2C1amrZF. However, you only need the pins. Should be an easy job once you get that plate off. When replacing worth using a little thread lock to ensure it remains tight. Vic Link to comment Share on other sites More sharing options...
kennydies Posted August 17, 2018 Share Posted August 17, 2018 Does anyone know what the clear stickers are for that are in the panniers? Link to comment Share on other sites More sharing options...
dedsxy47 Posted August 17, 2018 Share Posted August 17, 2018 Pic? My guess would be paint-protectors without seeing it, for that occasional boot that does not make it all the way over the bags. I know from experience from my FJR days Link to comment Share on other sites More sharing options...
quoman Posted August 18, 2018 Share Posted August 18, 2018 Exactly the same colour as mine! Really getting in to this machine! My wife has an MT09 in force amor (deep purple!) And she got me to get the one i have now. Link to comment Share on other sites More sharing options...
