cobby7 Posted May 1, 2015 Share Posted May 1, 2015 If anyone is feeling flush you can buy the rack from here for a cool £12000. http://www.hard-motorcycle-luggage.co.uk/acatalog/givi-sr2122-top-case-mounting-yamaha-mt-09-tracer-15-on.html Out of interest, whats the advantage/disadvantage of the SR2122 compared the the yamaha luggage rack? I've been given an E29 (monolock?) givi topbox with a universal base plate. Looks like I could screw it to a yamaha rack. Or for a similar price I could get the SR2122 with the m5m plate. I'll probably upgrade the topbox in the future, but i'm guessing even the givi rack can take adapters for other makes? (SW Motech Trax for example). Never had luggage before and just wanted a cheap option to get started really. Seemed a shame not to make use of this topbox. Link to comment Share on other sites More sharing options...
happy01 Posted May 1, 2015 Share Posted May 1, 2015 If anyone is feeling flush you can buy the rack from here for a cool £12000. http://www.hard-motorcycle-luggage.co.uk/acatalog/givi-sr2122-top-case-mounting-yamaha-mt-09-tracer-15-on.html Out of interest, whats the advantage/disadvantage of the SR2122 compared the the yamaha luggage rack? I've been given an E29 (monolock?) givi topbox with a universal base plate. Looks like I could screw it to a yamaha rack. Or for a similar price I could get the SR2122 with the m5m plate. I'll probably upgrade the topbox in the future, but i'm guessing even the givi rack can take adapters for other makes? (SW Motech Trax for example). Never had luggage before and just wanted a cheap option to get started really. Seemed a shame not to make use of this topbox. The Yamaha rack is not suitable for carrying boxes according to the instructions Link to comment Share on other sites More sharing options...
cobby7 Posted May 1, 2015 Share Posted May 1, 2015 I did see that actually. But then the bike isn't supposed to be able take panniers and top box but people are doing it. If it can take weight and you can secure it properly I don't see what difference it would make. How can they specify the type of luggage? Link to comment Share on other sites More sharing options...
Premium Member wessie Posted May 1, 2015 Author Premium Member Share Posted May 1, 2015 If anyone is feeling flush you can buy the rack from here for a cool £12000. http://www.hard-motorcycle-luggage.co.uk/acatalog/givi-sr2122-top-case-mounting-yamaha-mt-09-tracer-15-on.html Out of interest, whats the advantage/disadvantage of the SR2122 compared the the yamaha luggage rack? I've been given an E29 (monolock?) givi topbox with a universal base plate. Looks like I could screw it to a yamaha rack. Or for a similar price I could get the SR2122 with the m5m plate. I'll probably upgrade the topbox in the future, but i'm guessing even the givi rack can take adapters for other makes? (SW Motech Trax for example). Never had luggage before and just wanted a cheap option to get started really. Seemed a shame not to make use of this topbox. the SR2122 comes without a base plate so you can save yourself the £35 for an M5M plate and just use the universal plate you already have for your E29 box I'm sure it would be possible to fit other makes of base plate to the SR2122 rails The main advantage of the SR2122 is that some of the load is taken by the pannier rail mounts. Other plates just mounted to the grab handle mounts will put all of the load onto the rear subframe. I'd rather at least some of the load is taken by a part of the frame designed to take a luggage load. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
cobby7 Posted May 1, 2015 Share Posted May 1, 2015 Thanks Wessie. I'll try just the SR2122 then and see if the universal plate i have fits. Link to comment Share on other sites More sharing options...
cobby7 Posted May 3, 2015 Share Posted May 3, 2015 Does the m5m plate just bolt to the sr2122 rails? The universal Base plate I have is completely flat. I can't find a picture of just the rack to know what it'd look like with a flat plate on top. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted May 3, 2015 Author Premium Member Share Posted May 3, 2015 I think everyone has fitted either a M7 or M5 monokey plate as the Monokey boxes are larger and more substantial with a 3 point mounting system. These have holes that align with the holes pre-drilled on the brackets. In the unlikely situation where the M5M plate does not have holes predrilled in the right place it would be simple to make your own holes in the right place. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
Guest bmidd Posted May 3, 2015 Share Posted May 3, 2015 Ran into a fellow @ Deals Gap yesterday that had one of the Givi racks fitted to his, he ordered it through his company from Italy. It looked nice and hopefully they will distribute them in the US soon. Link to comment Share on other sites More sharing options...
cobby7 Posted May 18, 2015 Share Posted May 18, 2015 I didn't bother ordering the M5M, but should have! The universal base plate I have isn't big enough to attach to the SR2122 Link to comment Share on other sites More sharing options...
teacheruk Posted May 18, 2015 Share Posted May 18, 2015 Well my givi rack arrived last week and is all fitted. I'm using a monolock box , as it's what I had lying around but I intend to get the V47 carbon look with smoked reflectors so will need the monokey plate as well. Item arrived in around three weeks from Italy which was fater than Mand S newcastle and cheaper. I think the rack looks much nicer than the yamaha one which is HUGE ! Link to comment Share on other sites More sharing options...
peder Posted May 30, 2015 Share Posted May 30, 2015 Thanks for the tip regarding this kit, perfect for the tracer! I am considering ordering the led stop lights: http://www.accessorimotostore.com/index.php?main_page=product_info&cPath=1537_760_4726&products_id=16502 However, at the moment it's easy and convenient to take the box on/off, will that change with the lights installed..? Link to comment Share on other sites More sharing options...
Premium Member wessie Posted May 30, 2015 Author Premium Member Share Posted May 30, 2015 Thanks for the tip regarding this kit, perfect for the tracer! I am considering ordering the led stop lights: http://www.accessorimotostore.com/index.php?main_page=product_info&cPath=1537_760_4726&products_id=16502 However, at the moment it's easy and convenient to take the box on/off, will that change with the lights installed..? No, you get a connector, not unlike the sort of thing in a satnav cradle that transfers power from the base to the box - might even be some pictures if you search all the pages in this thread... This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
peder Posted June 12, 2015 Share Posted June 12, 2015 Help needed! I have just the last part of the installation left and I'm lost. How and to where do I connect the wires to the bike to get power? Link to comment Share on other sites More sharing options...
steve Posted June 15, 2015 Share Posted June 15, 2015 Have you sorted out the brake light connection? I have the V46 which doesn't have a dual connector, however I've foregone the brake light and have used the connector for a dual USB socket mounted in the top box. Initially I pushed the wire into an un-switched connection I found in the white connector block under the rider's seat (looking at the connector from the left hand side of the bike it is the right hand wire furthest away from you) having said that it's not something I was happy doing, I have no idea what I was piggy backing off. One of the members here has wired his to a PDM60 distribution box, the route I have subsequently taken. The unit is not cheap at £130, but will give you 6 power leads - it is an electronic fuse box, so if something does go wrong in the top box (or whatever else you hook up to it) the PDM will shut power till you recycle the power - provided the fault has been cleared the power is restored, no need for fuses. Link to comment Share on other sites More sharing options...
tdmtam Posted September 13, 2015 Share Posted September 13, 2015 Doing some homework on Givi for the Tracer and I came across a picture of an Aluminium mounting plate for the V45 topbox onto the Tracer (picture was apparently taken at the NEC bike show) does anyone have the part no for this??? http://i.imgur.com/di2gUhs.jpg http://i.imgur.com/woHXmcq.jpg Thanks Link to comment Share on other sites More sharing options...
