Ride365 Posted September 30, 2023 Share Posted September 30, 2023 On 9/28/2023 at 4:30 PM, Wintersdark said: Sure, it sucks, but if you look at the difference in cost between a slightly less fuel efficient flashed bike and a more fuel efficient but less fun unflashed bike... I'd pay the extra dollar, personally Used to be much cheaper to have fun, not very long ago. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted October 6, 2023 Supporting Member Share Posted October 6, 2023 On 9/27/2023 at 7:22 AM, Ride365 said: Running premium in this bike is certainly painful at the pump with these intentional gas prices, never dreamed I'd spend $40 worth of fuel on a good day ride. 😔 On 9/27/2023 at 10:34 AM, The Cheese said: Ive been able to find non ethanol locally. I've used that for the majority of my fill ups. I should have said that in the above post. E0 should be good for a slight MPG increase. I use it almost exclusively in my car. Which returns 36 mpg on my commute regularly btw. If I drive conservative I can get 40mpg. Just about the same as the Tracer. We have E0 available but at a hefty premium $$. I have used it but not noticed an increase in fuel economy, I mainly use it in the winter when the vehicles sit around idle and get used much less. Using it exclusively would cost me a fortune, @ $6.60 a gallon a typical day ride would be over $50 for gas + lunch. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 7, 2023 Premium Member Share Posted October 7, 2023 I think I paid last weekend about $4.39 for 91 E0. 😉 When I'm cheap I add regular or mid-grade into a half tank of premium. I have run mid-grade without apparent ill effects like pre-ignition or detonation based on reading the spark plugs and viewing th tops of the piston with a bore scope... Link to comment Share on other sites More sharing options...
