stevesweetz Posted August 2, 2017 Share Posted August 2, 2017 Every time I catch a glimpse of the rusty bottoms of my centerstand when the bike is parked on the kickstand, it bugs me a little. Do you think there's anything that you could paint those with that would hold up to the centerstand actually being used? I was wondering if truck bed liner would do the job. Link to comment Share on other sites More sharing options...
3banger Posted August 3, 2017 Share Posted August 3, 2017 Anytime I'm worried about corrosion I give it a quick coating of this ACF-50. https://www.amazon.com/Lear-Chemical-ACF50-Anti-Corrosion-Lubricant/dp/B000P1C8UO Both fresh brand new pipe nipples one treated with ACF-50, other just had a coating of cutting oil. Both lived on a fence post out side for 6 months. Link to comment Share on other sites More sharing options...
suncoaster Posted August 3, 2017 Share Posted August 3, 2017 I might try some phosphoric acid on mine. Link to comment Share on other sites More sharing options...
suncoaster Posted August 3, 2017 Share Posted August 3, 2017 Anytime I'm worried about corrosion I give it a quick coating of this ACF-50. https://www.amazon.com/Lear-Chemical-ACF50-Anti-Corrosion-Lubricant/dp/B000P1C8UO Both fresh brand new pipe nipples one treated with ACF-50, other just had a coating of cutting oil. Both lived on a fence post out side for 6 months. Which is which ? Link to comment Share on other sites More sharing options...
wordsmith Posted August 3, 2017 Share Posted August 3, 2017 I might try some phosphoric acid on mine. That'll remove the rust but won't prevent it from re-forming quick smart! A cuppla little leather bootees may do the job! Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 3, 2017 Premium Member Share Posted August 3, 2017 Maybe we should ask Yamaha to replace them all with Stainless Steel......... Link to comment Share on other sites More sharing options...
koth442 Posted August 3, 2017 Share Posted August 3, 2017 Every time I catch a glimpse of the rusty bottoms of my centerstand when the bike is parked on the kickstand, it bugs me a little. Do you think there's anything that you could paint those with that would hold up to the centerstand actually being used? I was wondering if truck bed liner would do the job. Bed liner would do the job just fine. '15 FJ09 Link to comment Share on other sites More sharing options...
josh Posted August 3, 2017 Share Posted August 3, 2017 I just keep a black touch up paint stick and give her a coat from time to time. Link to comment Share on other sites More sharing options...
vinnie Posted August 3, 2017 Share Posted August 3, 2017 I have bottomed out the center stand a whole bunch of times. That tube in the center of the two legs is scratched down to metal. I need to do something about that too.. Link to comment Share on other sites More sharing options...
pattonme Posted August 3, 2017 Share Posted August 3, 2017 truck bed liner spray. etch the metal a little bit first so it'll bind better. won't help Vinnie and dragging parts at road speed but should be just fine for normal wear and tear. Link to comment Share on other sites More sharing options...
crempel Posted August 6, 2017 Share Posted August 6, 2017 Vinnie, remove the little rubber bumper than stops the centerstand in the up position. Then take a nice sharp new razor blade and trim the thickness as much as you like. You will hardly believe how much extra ground clearance this will give you. $0 fix. Link to comment Share on other sites More sharing options...
empire00 Posted August 7, 2017 Share Posted August 7, 2017 Connie, remove the little rubber bumper than stops the centerstand in the up position. Then take a nice sharp new razor blade and trim the thickness as much as you like. You will hardly believe how much extra ground clearance this will give you. $0 fix. Wow I feel like a idiot for not even thinking of this as a option. You may have just single handedly saved the centerstand on my bike. Link to comment Share on other sites More sharing options...
wordsmith Posted August 7, 2017 Share Posted August 7, 2017 Connie, remove the little rubber bumper than stops the centerstand in the up position. Then take a nice sharp new razor blade and trim the thickness as much as you like. You will hardly believe how much extra ground clearance this will give you. $0 fix. Wow I feel like a idiot for not even thinking of this as a option. You may have just single handedly saved the centerstand on my bike. I must be missing something, for I cannot see how extra ground clearance on the c/stand - useful though it may be - will stop its feet from rusting... Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia. Link to comment Share on other sites More sharing options...
crempel Posted August 7, 2017 Share Posted August 7, 2017 It's always a good day when you help one person and confuse another. If you don't scrape the paint off something it won't rust, ergo you don't have to repaint it. Personally I find it too difficult to see the bottom of the centerstand feet while riding to worry about it. ? Link to comment Share on other sites More sharing options...
vinnie Posted August 7, 2017 Share Posted August 7, 2017 Connie, remove the little rubber bumper than stops the centerstand in the up position. Then take a nice sharp new razor blade and trim the thickness as much as you like. You will hardly believe how much extra ground clearance this will give you. $0 fix. I will definitely take a look at those bumpers now. Thanks for the tip! Link to comment Share on other sites More sharing options...
