M.G Posted March 16, 2019 Share Posted March 16, 2019 Hi, I have the larger of the 2 Yamaha top boxes available in the uk, it takes2 full face lids on their sides. It fits directly onto the top rack mounting which moves the pillion handles outwards. Takes seconds to remove with ignition key , It is waterproof and well made. Yamaha recommendation is not used in conjunction with side cases but I ignore that and just keep speed down when fully loaded, other half loves the back rest pad ! Link to comment Share on other sites More sharing options...
Premium Member 3sum Posted March 17, 2019 Premium Member Share Posted March 17, 2019 I have the Yamaha topcase too. Mine has its own key and doesn’t use the ignition key. I wish it did, though! i do like the case as well. My 14 year old says he doesn’t need the backrest pad, luckily. Link to comment Share on other sites More sharing options...
kmev Posted March 17, 2019 Share Posted March 17, 2019 15 hours ago, 3sum said: I have the Yamaha topcase too. Mine has its own key and doesn’t use the ignition key. I wish it did, though! i do like the case as well. My 14 year old says he doesn’t need the backrest pad, luckily. Disassemble the case lock, insert your ignition key into lock barrel, grind down any protruding tumblers while the key remains in the lock, reassemble lock, toss the case key in the trash. 3 Link to comment Share on other sites More sharing options...
SC3896 Posted August 3, 2019 Share Posted August 3, 2019 On 10/27/2018 at 2:09 PM, gv550 said: I have the Yamaha 50L top case and it mounts directly to the Yamaha luggage rack. No adaptor needed. Is the 50L top box waterproof ? Thanks Link to comment Share on other sites More sharing options...
mawbkk Posted August 3, 2019 Share Posted August 3, 2019 I just fitted the Yamaha rear rack, apparently the max load is 5KG? Link to comment Share on other sites More sharing options...
SC3896 Posted August 3, 2019 Share Posted August 3, 2019 18 minutes ago, mawbkk said: I just fitted the Yamaha rear rack, apparently the max load is 5KG? Yes that is what the rack states. Link to comment Share on other sites More sharing options...
harraseeket Posted August 5, 2019 Share Posted August 5, 2019 yamaha sells a key kit that will allow to match ignition Link to comment Share on other sites More sharing options...
gv550 Posted August 7, 2019 Share Posted August 7, 2019 On 8/3/2019 at 3:32 AM, SC3896 said: Is the 50L top box waterproof ? Thanks Yes, but only when it is closed. 😁 2 3 2019 Tracer GT, Ontario, Canada Link to comment Share on other sites More sharing options...
OLDESTP Posted November 11, 2019 Share Posted November 11, 2019 Sorry to resurrect but similar to my questions about the Yamaha top rack. I went to order today here in Australia but as with everywhere it has the warning about not using it with the Yamaha side cases. Or if it is used keep weight down. Is this because of its 4 mounting points or some other reasons ? Is it the same for using a Givi or Shad setup as they do mount differently than the Yamaha setup. Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted November 11, 2019 Supporting Member Share Posted November 11, 2019 6 hours ago, OLDESTP said: Sorry to resurrect but similar to my questions about the Yamaha top rack. I went to order today here in Australia but as with everywhere it has the warning about not using it with the Yamaha side cases. Or if it is used keep weight down. Is this because of its 4 mounting points or some other reasons ? Is it the same for using a Givi or Shad setup as they do mount differently than the Yamaha setup. @OLDESTP, it has to do with the weight and how far back it is positioned on the bike. Just use a little common sense and you will be fine. Other wise your GT will be real wheelie prone, our bike are very light on the front wheel as it is. 1 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted November 11, 2019 Supporting Member Share Posted November 11, 2019 2 hours ago, roadrash83 said: Just use a little common sense and you will be fine. Exactly this... I have the factory Yamaha saddlebags and rear rack on my Gen 1 FJ, and everything fits & works fine together. While I don’t use a top box on my bike, I’ve had zero issues with things I’ve tied down on the rack over the years. Just don’t put excessive amounts of weight too far back and up - and keep the speeds down to reasonable levels - and you’ll be fine. Link to comment Share on other sites More sharing options...
OLDESTP Posted November 11, 2019 Share Posted November 11, 2019 Thanks for the replies, I thought as much. I will still go with the Yamaha rack and take is easy on the weight. I don’t normally overload my top box as it normally only carries my rain gear, drink etc. Just no cartons of beer... Link to comment Share on other sites More sharing options...
JimT Posted November 13, 2019 Share Posted November 13, 2019 On 11/11/2019 at 2:38 PM, OLDESTP said: Thanks for the replies, I thought as much. I will still go with the Yamaha rack and take is easy on the weight. I don’t normally overload my top box as it normally only carries my rain gear, drink etc. Just no cartons of beer... I have factory panniers and 50 litre top case. I did a 6200 kilometer trip with bike fully loaded including top case. Tried to keep lighter items in top case. had no problems with sustained 90 miles per hour interstate runs and the occasional 120 MPH passing transport trucks. Just test the load a little at a time you will know when it is too much. I found the bike stable enough without any issues. I will pack lighter nest time though. I only used half of what I brought with me. 1 Link to comment Share on other sites More sharing options...
harraseeket Posted November 17, 2019 Share Posted November 17, 2019 makes riding pillion change from about the least fun thing to do, to relaxing. having ridden pillion once to get back home from having flat tire on my bmw 60 / 2, i have always been amazed that anyone would actually do it by choice. Link to comment Share on other sites More sharing options...
