BarryGT Posted August 26, 2022 Share Posted August 26, 2022 I have 830 km on my bike am I'm planning on a long ride. Should I change the oil now or wait until my ride is over? Link to comment Share on other sites More sharing options...
Ride365 Posted August 26, 2022 Share Posted August 26, 2022 Wait...... Link to comment Share on other sites More sharing options...
BarryGT Posted August 26, 2022 Author Share Posted August 26, 2022 What is the maximum mileage I should be cautious about? Link to comment Share on other sites More sharing options...
MightBeSasquatch Posted August 26, 2022 Share Posted August 26, 2022 Depends how long the ride is I would say.... This whole "break in" subject can be contentious. If your first 830 km were spirited enough I'd say change it now and before you winter it. 1 Link to comment Share on other sites More sharing options...
PhotoAl Posted August 26, 2022 Share Posted August 26, 2022 I would go ahead and change it now. Think 1st is at 1,000 km so close enough. I had 629 miles on mine at 1st service but that was over 3 days so only 3 of starts from cold. Link to comment Share on other sites More sharing options...
kilo3 Posted August 26, 2022 Share Posted August 26, 2022 Depends on how old and grouchy you are, I'm plenty grouchy so I dump my oil as soon as i passed 100 freedom units to get the bits and pieces out. Then again at 1k because I use oil made from eagle feathers and that stuff expires. Link to comment Share on other sites More sharing options...
Grumpy Goat Posted August 26, 2022 Share Posted August 26, 2022 6 hours ago, BarryGT said: I have 830 km on my bike am I'm planning on a long ride. Should I change the oil now or wait until my ride is over? I suggest you change it now as you are close enough to the conventional first oil change of 600 miles. First oil change usually has the most stuff in the oil and you are saving nothing by waiting. Later oil changes can be more safely stretched out. Regards, Grumpy Goat | 2019 Yamaha Tracer 900 GT & 2016 BMW R1200RS Link to comment Share on other sites More sharing options...
afineAmerican Posted August 27, 2022 Share Posted August 27, 2022 No harm in changing it now. The first few thousand miles are critical to the longevity of the motor. 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 27, 2022 Premium Member Share Posted August 27, 2022 I agree with kelo in fact I change the Motor oil but not necessarily the filter in a 100 miles or less because that's when all the bits are mating with each other and come loose Going through 5 or 6 heat cycles in the 1st 100 miles is best for wearing-in I'm sort of the type who says ride it like is stole it from day one 2nd oil change with filter with filter at 5 or 600 miles After 3 or 4000 miles you can switch from regular Dino oil to a full synthetic like shell rotella t6 5W40 even though they say go with 10W40 Hasn't bothered my 100000 plus mile bikes one iota with the slightly lighter bottom weight Link to comment Share on other sites More sharing options...
ZigMerid Posted August 27, 2022 Share Posted August 27, 2022 (edited) 3 hours ago, afineAmerican said: No harm in changing it now. The first few thousand miles are critical to the longevity of the motor. Agreed. If you're old skool and think that the run-in period is when the metal surfaces are getting all friendly with each other and microscopic metal fragments are deposited into the oil, then your initial batch of oil and the oil filter have already done the hard yards at 830km (hard meters maybe?). Better not to have that goop in the system any longer than necessary if you're going on an extended trip. I don't know whether it's still true, but I was under the impression that the initial batch of oil is especially selected for run-in and may differ from the regular oil used at each change. Does anyone know whether this is still the case? Edited August 27, 2022 by ZigMerid Link to comment Share on other sites More sharing options...
BarryGT Posted August 27, 2022 Author Share Posted August 27, 2022 I believe there are additives for break in, hence the 1000 km change schedule. I went ahead and changed the oil and filter. Link to comment Share on other sites More sharing options...
kilo3 Posted August 27, 2022 Share Posted August 27, 2022 7 hours ago, ZigMerid said: I don't know whether it's still true, but I was under the impression that the initial batch of oil is especially selected for run-in and may differ from the regular oil used at each change. Does anyone know whether this is still the case? No that's also a hold over of lore from the 70-80's. Lot of people still believe it, along with somehow thinking an OEM engine needs to break in. This ain't no V8 you out together in your crusty ass garage with only a cylinder hone. 2 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 27, 2022 Supporting Member Share Posted August 27, 2022 22 hours ago, BarryGT said: I have 830 km on my bike am I'm planning on a long ride. Should I change the oil now or wait until my ride is over? Considering how many particles I found in the oil on the first change, I would do it now. I changed mine at 100 miles and there was a lot of silvery particles, I changed it again at 1000 miles and then normal intervals thereafter. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
oregonian Posted August 27, 2022 Share Posted August 27, 2022 Now that the OP has changed the oil and settled the topic, can we discuss when he/she should switch to synthetic oil and whether or not semi-synthetic is a recommended step along that route? 2 Link to comment Share on other sites More sharing options...
miweber929 Posted August 27, 2022 Share Posted August 27, 2022 2 minutes ago, oregonian said: Now that the OP has changed the oil and settled the topic, can we discuss when he/she should switch to synthetic oil and whether or not semi-synthetic is a recommended step along that route? Most motors nowadays are coming right from the factory with synthetic oil so change when you want to change, and semi synthetic is fine as well. I run full Shell “Ducati” synthetic in my Ducati, Maxima semi synthetic in my “older” bikes and put the Yamaha branded non-racing synthetic into the Tracer. All work great. Link to comment Share on other sites More sharing options...
