Supporting Member Heli ATP Posted December 18, 2023 Supporting Member Share Posted December 18, 2023 I just read that waterproof gloves will no longer be waterproof, if used with heated grips in the rain. Anyone experience this? It seems this is not an issue for heated gloves as the heat is inside, whereas heated grips provide heat from the outside. Who has the scientific explanation for this? Link to comment Share on other sites More sharing options...
Supporting Member jthayer09 Posted December 18, 2023 Supporting Member Share Posted December 18, 2023 31 minutes ago, knyte said: I saw something recently (might have been Fortnine / F9?) that reasoned this is intentional because your left will need more heat because it'll be on the grip 100% of the time, and therefore exposed to more cold air. Maybe I'm misunderstanding what you wrote, but the issue is that the left-hand side of the handlebar has less heat because the heat from the grip gets absorbed by the cold metal of the handlebar; which is why we're recommending users insulate the handlebar with tape before installing a heated grip. You're saying this is intentional because the left needs more heat? 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted December 18, 2023 Supporting Member Share Posted December 18, 2023 Nope, I misread something; we're on the same page. I was attempting (poorly) to add that aftermarket and factory grips etc commonly are warmer on the left side for the same reason - bare metal: Again, my bad! 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted December 18, 2023 Premium Member Share Posted December 18, 2023 2 hours ago, knyte said: I saw something recently (might have been Fortnine / F9?) that reasoned this is intentional because your left will need more heat because it'll be on the grip 100% of the time, and therefore exposed to more cold air. Huh? Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted December 18, 2023 Supporting Member Share Posted December 18, 2023 1 hour ago, 2and3cylinders said: Huh? Misfire on my part 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Ride365 Posted December 18, 2023 Share Posted December 18, 2023 10 hours ago, Heli ATP said: I just read that waterproof gloves will no longer be waterproof, if used with heated grips in the rain. Anyone experience this? It seems this is not an issue for heated gloves as the heat is inside, whereas heated grips provide heat from the outside. Who has the scientific explanation for this? I personally have yet to find a waterproof glove, although what I do have is quite good and am bummed no longer made "imagine that". Heated gloves are too bulky for me, I like as much dexterity as possible when I ride. Link to comment Share on other sites More sharing options...
draco_1967 Posted December 19, 2023 Share Posted December 19, 2023 I wired up some Heat Demon heaters under my stock grips on my 2019 non-GT. I picked up some OEM turn signal connectors, and wired them according to a diagram in another thread here. Since they are wired in to the factory location, they work with the dash/handlebar controls. No extra buttons anywhere. They get HOT too. I only put them on the high setting when I first start out on a very cold morning. 1 1 Link to comment Share on other sites More sharing options...
ItsTracerTime Posted December 20, 2023 Author Share Posted December 20, 2023 Home Depot/Lowe's sells small pieces of heat shrink for 8/2 wire, which happens to be a snug 7/8" inner diameter but maybe too thick compared to tape. I'm still torn on OEM or Oxford, OEM would seemingly have to come from Europe and Oxford would require aftermarket terminals or wiring work to connect Link to comment Share on other sites More sharing options...
RomKnight Posted December 20, 2023 Share Posted December 20, 2023 Well, the GT+ tracer9 has them factory fitted. But if they're the same for the other Yamaha current models, I recommended them. Obviously, if there's cheapest option doing the same the choice I would do was based on practical use; these don't need another plastic controller hanging on the handle bar. Link to comment Share on other sites More sharing options...
Supporting Member jthayer09 Posted December 20, 2023 Supporting Member Share Posted December 20, 2023 On 12/17/2023 at 7:14 PM, Heli ATP said: I just read that waterproof gloves will no longer be waterproof, if used with heated grips in the rain. Anyone experience this? It seems this is not an issue for heated gloves as the heat is inside, whereas heated grips provide heat from the outside. Who has the scientific explanation for this? The only explanation for this that I could possibly think of: back when Gore-Tex's original patent for ePTFE was still active, that patent prevented other manufacturers from creating their own waterproof ePTFE membrane unless they bought Gore-Tex equipment & materials, paid for the license, and put a Gore-Tex label on the final product. Waterproof gear at the time that wasn't made from ePTFE would have relied on DWR (Durable Water Repellent, like Nikwax) coating that wears off over time. It's possible the heat from motorcycle grips accelerated this wear, that's really the only feasible way you'd lose waterproofing due to heat. Gore-Tex's patent expired in 1998, and today all waterproof motorcycle gear is waterproofed with an ePTFE membrane manufactured in-house or by a third party, there will be no issues with heated grips. On 12/18/2023 at 6:12 AM, Ride365 said: I personally have yet to find a waterproof glove, although what I do have is quite good and am bummed no longer made "imagine that". Heated gloves are too bulky for me, I like as much dexterity as possible when I ride. Not sure what brands you're buying but any of the big 3 EU brands have solid in-house membranes that haven't failed on me yet over 5+ years since owning: Rev'it, Dainese, and Alpinestars. I also have some gear in other brands that use Hipora as the membrane and that has held up. For bulky heated gloves/winter gloves there are pairs that don't have insulation in the palm and underside of the fingers so the dexterity is still there and you actually feel your heated grips better; maybe that is worth looking into? 2 Link to comment Share on other sites More sharing options...
