skipperT Posted August 8, 2020 Share Posted August 8, 2020 (edited) Ok, I can’t not say anything anymore about this..... you Guys do realize that the mirror screws into the mounting point of the handlebar first, at which point you tighten one locknut, then find an appropriate position and tighten the second nut AGAINST the first nut? EDIT - older models only- This is what secures the mirror. You should have no reason to attempt to tighten the nut that’s under the rubber cap. I’ve been doing this a long time, and I’ve NEVER had to touch one of those nuts with a socket to get the mirror to stay secure and not blow back in the wind while riding. (that’s a lot of talk about nuts, yeah I know...) -Skip Edited August 8, 2020 by skipperT 1 Link to comment Share on other sites More sharing options...
mingo Posted August 8, 2020 Share Posted August 8, 2020 1 hour ago, skipperT said: tighten one locknut, then find an appropriate position and tighten the second nut AGAINST the first nut? -Skip that's just it, there aren't 2 nuts! There's only one, hence our dilemma. Virtually all other bikes I've had with mirrors attached to the handlebars have 2 nuts, one tightens against the other and the mirror doesn't move. Link to comment Share on other sites More sharing options...
Buggy Nate Posted August 8, 2020 Share Posted August 8, 2020 You are forgetting about the nut holding the handlebars. 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 8, 2020 Supporting Member Share Posted August 8, 2020 (edited) 1 hour ago, mingo said: that's just it, there aren't 2 nuts! There's only one, hence our dilemma. I hold the mirror stalk in place with my hand and jam the "nut" agaist the clamp side bracket... no? Is it the stud inside the mirror stalk that comes loose (inside)? Edited August 8, 2020 by piotrek 1 1 Link to comment Share on other sites More sharing options...
skipperT Posted August 8, 2020 Share Posted August 8, 2020 1 minute ago, piotrek said: I hold the mirror stalk in place with my hand and jam the "nut" agaist the clamp side bracket... no? Is it the stud inside the mirror stalk that comes loose inside? That’s how I’ve always done it too... —s 2 Link to comment Share on other sites More sharing options...
skipperT Posted August 8, 2020 Share Posted August 8, 2020 (edited) 9 hours ago, mingo said: that's just it, there aren't 2 nuts! There's only one, hence our dilemma. Virtually all other bikes I've had with mirrors attached to the handlebars have 2 nuts, one tightens against the other and the mirror doesn't move. Ok, I see now - I think Yamaha changed the mirrors - Tracer 900 and GT models have a new style mirror (along with a couple other models...) *snip and delete* I’ve been tightening the stalk into the mount (as I mentioned) which then also partially rotates the mount for the hand guard, so hold that with your third hand. Once secure, gently rotate the mirror toward the desired position. Better to go in the same direction of travel you were just using to screw the mirror in (RH side is LH thread I believe). I haven’t had one not stay put yet. 🤷♂️ -Skip Edited August 9, 2020 by skipperT Incorrect information, sorry y’all!!! Link to comment Share on other sites More sharing options...
mingo Posted August 8, 2020 Share Posted August 8, 2020 (edited) 14 minutes ago, piotrek said: I hold the mirror stalk in place with my hand and jam the "nut" agaist the clamp side bracket... no? Is it the stud inside the mirror stalk that comes loose (inside)? that's what I did after my last ride.. tomorrow I'll find it if it holds or moves.. The mirror moves at high speeds (140 - 150 km/h (90/95 mph) on short bursts when passing. Hopefully it won't move now. Edited August 8, 2020 by mingo Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 8, 2020 Supporting Member Share Posted August 8, 2020 1 minute ago, mingo said: ...that's what I did after my last ride.. tomorrow I'll find it if it holds or moves.. The mirror moves at high speeds (140 - 150 km/h (90/95 mph) on short bursts when passing. Hopefully it won't move now. Mine will also move a little at high speed sometimes, but I find that it is the business end (mirror) that moves, not the stalk itself. 🤔 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 9, 2020 Supporting Member Share Posted August 9, 2020 1 hour ago, skipperT said: Tracer 900 and GT models have a new style mirror ...don't know Skip... looking at photos on the web, the stalk/mount itself looks the same as my 2015. Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted August 9, 2020 Supporting Member Share Posted August 9, 2020 3 hours ago, skipperT said: No 2 nuts anymore. Pretty sure my ur-FJ09 (15) has a 2 nut setup but I’ll check when I get home Curiosity (and pandemic boredom) inspired me to make the 50 foot journey out to the shop and have a look... My 2015 FJ is definitely a single nut bottom mount, with the right side being a reversed thread (the nut on the right has a hash mark to indicate such) 2 Link to comment Share on other sites More sharing options...
Supporting Member whistler Posted August 9, 2020 Supporting Member Share Posted August 9, 2020 11 hours ago, Wintersdark said: @mingo To tighten the mirror, you take off the black cap and tighten the nut inside. You'll need a thin 10mm socket to do it. Only tighten it a tiny bit, like 1/8th of a turn, and be careful - don't want what happened to @TheBigG happening to you I've had this Floppy Mirror Syndrome on both the new Yamaha's I've owned (both with the same types of mirrors) and an 1/8th of a turn on that nut has fixed both. +1. Did this to mine, as well. Just ground down the circumference of a 10mm socket a little on a bench grinder; a Dremel or the like would work fine, too. The modded socket worked like a champ. Then got the urge for something different entirely and installed some Puig mirrors. 😉 2 2019 Yamaha Tracer 900 GT (Annabelle) 2013 Suzuki V-Strom DL650 (Juliette) 2013 Yamaha FJR 1300 (Rachel) 2008 Suzuki Bandit 1250S (Fiona) 2006 Honda VFR800 (Jenny) 2005 Suzuki V-Strom DL650 (Hannah) 2003 Honda Shadow Sabre VT1100 (Veronica) Link to comment Share on other sites More sharing options...
skipperT Posted August 9, 2020 Share Posted August 9, 2020 7 hours ago, skipperT said: Ok, I see now - I think Yamaha changed the mirrors - Tracer 900 and GT models have a new style mirror (along with a couple other models...). No 2 nuts anymore. Pretty sure my ur-FJ09 (15) has a 2 nut setup but I’ll check when I get home. You Tracer guys with newer bikes could always order the original mirrors and “update” them. I’ve been tightening the stalk into the mount (as I mentioned) which then also partially rotates the mount for the hand guard, so hold that with your third hand. Once secure, gently rotate the mirror toward the desired position. Better to go in the same direction of travel you were just using to screw the mirror in (RH side is LH thread I believe). I haven’t had one not stay put yet. 🤷♂️ Way to go and update something that wasn’t broken, Yamaha. -Skip Umm ok so my memory isn’t as good as I thought, single nut on my mirrors also. sorry folks, i have nothing to add to this discussion that may help with the loose mirrors... Not sure what I was remembering. My apologies for de-railing this thread. -Skip 2 Link to comment Share on other sites More sharing options...
TheBigG Posted August 9, 2020 Author Share Posted August 9, 2020 I fixed it and it is better than before! 😀 4 4 Link to comment Share on other sites More sharing options...
mingo Posted August 9, 2020 Share Posted August 9, 2020 This is a better design than the original. Thanks for sharing your pics 👍 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 9, 2020 Supporting Member Share Posted August 9, 2020 7 hours ago, skipperT said: Umm ok so my memory isn’t as good as I thought, single nut on my mirrors also. sorry folks, i have nothing to add to this discussion that may help with the loose mirrors... Not sure what I was remembering. My apologies for de-railing this thread. -Skip It happens to us all... more often than I like to admit. ☹️ Regardless, you always seem to offer some of the most 'technical' help on this forum, much appreciated. Are you a current bike technician? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
