RollIt 4 Posted February 11 2016 FJ09, Bike on centre stand, when i put 1st gear (clutch pulled in) the rear wheel spins at 8mph at idle throttle. Release the clutch completely and it still spins at 8mph. This is with cold engine at around 65F ambient temperature. I didn't check with warm/hot engine yet. Is this normal clutch drag? Share this post Link to post Share on other sites
knyte 317 Posted February 11 Mine does this, too. Seems to stop when it gets up to temp. 2 2015 red FJ-09 / touring bags / oil plug mod Share this post Link to post Share on other sites
duhg 238 Posted February 11 Mine is very similar. The wheel spins more as you described than any of the 9 previous bikes I've owned. Pushing it around in the garage requires the transmission be shifted to neutral. On the road, at stop signs, in parking lots, etc... I don't notice any problem. 2 www.ridemsta.com Riding makes me happy. Life is short, go outside and play. 2015 matte gray, Hord Power ECU, K-Tech suspension, MC Cruise Share this post Link to post Share on other sites
Ride365 253 Posted February 11 Yup it's called clutch drag and totally normal at temps below 60F, it goes away quickly though once some warm oil hits the clutch basket. 3 Share this post Link to post Share on other sites
whisperquiet 117 Posted February 11 It is a good speed to lube the chain. 1 3 Share this post Link to post Share on other sites
knyte 317 Posted February 11 haha I have done that!! 1 1 2015 red FJ-09 / touring bags / oil plug mod Share this post Link to post Share on other sites
betoney 4,885 Posted February 12 24 minutes ago, whisperquiet said: It is a good speed to lube the chain. 18 minutes ago, knyte said: haha I have done that!! I use that method after every single ride. A quick shot of chain lube, let it spin for a few seconds, wipe off excess with a rag, - done. 👍 3 ***2015 Candy Red FJ-09*** Share this post Link to post Share on other sites
fddriver2 1,819 Posted February 12 Normal. When the oil warms up. It will stop 3 "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Share this post Link to post Share on other sites
RollIt 4 Posted February 12 4 hours ago, whisperquiet said: It is a good speed to lube the chain. haha i found it during lubing the chain itself Share this post Link to post Share on other sites
RollIt 4 Posted February 12 7 hours ago, duhg said: Mine is very similar. The wheel spins more as you described than any of the 9 previous bikes I've owned. Pushing it around in the garage requires the transmission be shifted to neutral. On the road, at stop signs, in parking lots, etc... I don't notice any problem. yeah it feels a bit of work to roll backwards, that's why i was worried if something is wrong. Thanks for sharing your experience! 1 Share this post Link to post Share on other sites
RollIt 4 Posted February 12 Thank you everyone, i think i should stop fretting about it! Share this post Link to post Share on other sites
Junkie 5 Posted February 12 For anyone suggesting lubing the chain like that... I recommend against it. Lots of people have lost fingers that way. If you insist, at least please don't try to clean the chain that way. Be very careful, don't use a rag, just lube. 2 Share this post Link to post Share on other sites
skipperT 972 Posted February 14 Also on newer models (17 and up?) it’s possible to set a Check Engine light that has to be cleared by the dealer or with an OBDII reader and adapter. leaving the engine off is much safer. -Skip 1 Share this post Link to post Share on other sites
Jfundo 33 Posted February 15 In my mind the wheel spins like this because your friction clutch is acting a bit like a torque converter in an automatic transmission. Just the fluid is spinning around and transfers some of the torque. Once the fluid gets hot and thins out it doesn't transfer the torque as well anymore. 1 Share this post Link to post Share on other sites
RollIt 4 Posted February 17 (edited) On 2/11/2021 at 5:58 PM, fddriver2 said: Normal. When the oil warms up. It will stop ok, here's the update. It didn't stop after warming up (after 1 hour riding)! Even with hot engine it spins at same 8mph. Something to worry/fix now? Edited February 17 by RollIt Share this post Link to post Share on other sites
