skipperT Posted August 11, 2023 Share Posted August 11, 2023 (edited) Glad you figured it out. As I mentioned above, it’s easy to bonk the encoder ring with a tire iron, the bead removal foot of the tire machine, or on the “feet” which you set the rim into on the tire machine. Or maybe it was something else, but food for thought regardless. -Skip Edited August 11, 2023 by skipperT 1 Link to comment Share on other sites More sharing options...
etex Posted August 11, 2023 Share Posted August 11, 2023 A Super Thumbs UP to Rdecae81 for posting the answer to the problem, which could have happened to anybody. But now "anybody" now has additional information on what to avoid! 1 Link to comment Share on other sites More sharing options...
Rdecae81 Posted August 11, 2023 Author Share Posted August 11, 2023 I have been changing my own tires for 20+ years. Never had a ring or sensor damage. I am just guessing I messed up somehow. But honestly cannot remember anything going unusual in this tire change. But lesson learned, no matter how long I have been doing something, do not get complacent. And again, I did this tire change on the floor of my garage. So I am guessing that was the variable. Once I had my lift working, the rear tire removal, ring swapped out and rear tire installed it was a smooth process. 2 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 12, 2023 Premium Member Share Posted August 12, 2023 For the first 22 years I used tire irons and then graduated to irons, Bead Breezer and zip ties on a steel welding table. Lube was always experimental Then in 95 I built the Bret Cave and got off the floor or work table onto 22 feet of work bench and got a Handy Lift and dolly lift. My front and rear Pit Bull stands are ancient but still kickin. Modified a Harbor Frieght tire changer, then in 06 bought a NoMar Classic and later their wheel balancer. Do your body a favor and look at some of the several changers now available. Knock on plastic I've never damaged a wheel, rotor or ABS ring or sensor (yet). Of course my 15 Fastest Red FJ is my first bike with ABS, TC & FI BTW a bead blast cabinet and 000000 grit glass microballoons is a great way to clean brake rotors. Link to comment Share on other sites More sharing options...
Rdecae81 Posted August 13, 2023 Author Share Posted August 13, 2023 actually I bought my NoMar classic in 2006. I also have a balancer. I have all the tools to do the job correctly. I have probably now changed close to 500 tires in my last 20 years of tire changing. I also started out with a harbor freight tire changer 🙂 and like I said, I have a lift it was just in for maintenance, so that was the variable. 1 Link to comment Share on other sites More sharing options...
duckie Posted August 13, 2023 Share Posted August 13, 2023 I always find reasons its not my fault when I screw up…… 1 Link to comment Share on other sites More sharing options...
Rdecae81 Posted August 13, 2023 Author Share Posted August 13, 2023 (edited) yea not the case this time, I removed the tires, I changed the tires, and I installed the tires, all by myself. So I have no idea what I did wrong, but I only have myself to blame. but I do think if my lift was working, the problem would not have occurred. Edited August 13, 2023 by Rdecae81 2 Link to comment Share on other sites More sharing options...
Rdecae81 Posted March 2 Author Share Posted March 2 it has been a while since this happened. but i wanted to note the great customer service from OBDLink MX+ my unit stopped working, I contacted support, and they sent me a replacement. Replacement came in and connected right up and cleared my code. (let battery die, so I got low voltage code) great customer service. 1 Link to comment Share on other sites More sharing options...
