nickest85 Posted November 12, 2017 Share Posted November 12, 2017 Only one side is cracked slightly, I botched them out like the replacement panels are. I would probably care more about it if the crack was visible with the seat on Link to comment Share on other sites More sharing options...
dundee Posted November 15, 2017 Share Posted November 15, 2017 My dealer replaced my side covers under warranty; I provided the new part numbers to my dealer based on info in this forum. The new parts cost about $45 in total and are: COVER, SIDE 1 2PP-24129-01-00 (replaces 2PP-24129-00-00) COVER, SIDE 2 2PP-24139-01-00 (replaces 2PP-24139-00-00) At $45 for parts, this did not break the bank for Yamaha and they should rightfully replace the side covers as it is a design defect. One of my side covers (left side) was very badly cracked (@ 5,000 miles) and the right side was not yet cracked but had indentation marks on it from the seat resting on it so it would have cracked soon. My seat is in the low position. I do have the plastic seat base installed and I make sure the seat tongue is properly inserted in the gas tank bracket. The notch in the redesigned side cover part should prevent the seat from contacting the side covers in the future, which was the root cause of the crack. On different rides, I have had many compliments about the preciseness of the side covers and that they look cool. Link to comment Share on other sites More sharing options...
silverninja Posted November 16, 2017 Share Posted November 16, 2017 '16 both side panels cracked - I glued the inside with epoxy so they wouldn't get an worse. Seat is in low position. Link to comment Share on other sites More sharing options...
kimmie Posted November 16, 2017 Share Posted November 16, 2017 Both of mine are cracked but only in the last 6 months. I've put some tape around them to hold them but not really bothered as you can't see it. Kimmie......the lady who likes to take little detours Link to comment Share on other sites More sharing options...
metallion Posted November 16, 2017 Share Posted November 16, 2017 I just saw this thread yesterday so i checked my bike last night as i was prepping it for winter storage. MY 2016 has 2,713 miles on it and no cracks yet. I wonder if having an aftermarket seat on it makes any difference or is it generally random? I've only owned the bike for a couple months and put 900 miles on it. I use the low seating position but the previous owner had it set in the high position. He also added some pvc tubing between the frame and the height adjustment bracket to boost it another 3/8" higher. I wonder if this was help prevent cracking or perhaps he was just really tall. 2019 Tracer 900 GT. 2022 MT-09SP. 2002 Buell S3T Thunderbolt. 2016 FJ-09 SOLD. 2019 XSR900 SOLD. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 16, 2017 Premium Member Share Posted November 16, 2017 I just saw this thread yesterday so i checked my bike last night as i was prepping it for winter storage. MY 2016 has 2,713 miles on it and no cracks yet. I wonder if having an aftermarket seat on it makes any difference or is it generally random? I've only owned the bike for a couple months and put 900 miles on it. I use the low seating position but the previous owner had it set in the high position. He also added some pvc tubing between the frame and the height adjustment bracket to boost it another 3/8" higher. I wonder if this was help prevent cracking or perhaps he was just really tall. Mine cracked with the stock seat. Let’s go Brandon Link to comment Share on other sites More sharing options...
duhs10 Posted November 16, 2017 Share Posted November 16, 2017 @metallion I think the '16s and newer have an updated side panel with 2 cutouts where the seat would otherwise contact the panels Mine have been cracked for over a year... I never did anything to correct it and the cracks have not grown. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
xcsp Posted November 16, 2017 Share Posted November 16, 2017 My '16 didn't have the revised panels but I did modify them as they were very close to making contact with the aftermarket seat. Easy to make the necessary clearance needed to avoid a possible crack. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted November 17, 2017 Premium Member Share Posted November 17, 2017 I notched mine as a preventative measure but neither with the OEM or Sargent front saddle did it touch, at least in the upper saddle setting on my 2015. Link to comment Share on other sites More sharing options...
