lapuree Posted February 25, 2016 Share Posted February 25, 2016 After trying many different sprays (and even spending 120€ on a Cameleon oiler a few years back - hated it), I use Elf chain paste with a toothbrush. The good thing about the paste is that unlike sprays, you don't lube your garage floor and half the engine ;-) (or have to put protective sheets to prevent that). It's pretty popular in France, not sure of the availiblity elsewhere. [EDIT] : Motul has one with an "integrated toothbrush", might be worth a try http://www.amazon.com/Motul-Chain-Lube-Paste-5-7oz/dp/B008KJT2SE for about the same price, $9. You might want to apply a bit less product than this fellow did, though ;-) Link to comment Share on other sites More sharing options...
Premium Member peporter Posted February 25, 2016 Premium Member Share Posted February 25, 2016 It sounds so wrong. "Good for NON Metal surfaces" on the can? Silicone is not suppose to be good in compression as what happens a little on the sprokets. How Long do your chains last? And how many have you used using silicone? Just asking. This was the report I read and started from. The DuPont product is a silicon and Teflon mix. My chain has lasted half again as long since switching to this product. http://www.webbikeworld.com/t2/motorcycle-chain-lube/dupont-teflon-chain-saver/ I have and still use the "old" formula Teflon Multi-Use Dry, Wax Lubricant. Stocked up on it while it was still available. I used it exclusively on my DL1000 V Strom from the beginning. Others were reporting chains needing replacement after 12,000 miles, and on the stock chain I got 22,000 miles. My regimen was to lube the chain every 1,000 miles whether it needed it or not. That included a Great Divide Ride. Don't know about the new formula, but the old one really worked! Link to comment Share on other sites More sharing options...
bobdog Posted March 2, 2016 Share Posted March 2, 2016 Has anyone tried "Blaster" chain and cable lube? Supposed to have teflon in it. Bought a can to replace LucasOil chain lube which leaves a mess if you ride at highway speeds. Just worried that it might not cushion the chain as real oils do. 2015 Grey FJ09 with a few tweaks, 2007 HD Street Glide - Good Bike + Good Friends = Good Day. Link to comment Share on other sites More sharing options...
gabefzr6 Posted March 3, 2016 Share Posted March 3, 2016 I'm under the impression that chain lube doesn't do much cushioning. I think the internal lubrication takes care of that. 2008 Street Triple G 2015 FJ-09 Link to comment Share on other sites More sharing options...
kd7vdb Posted March 3, 2016 Share Posted March 3, 2016 I am using the Maxima Chain Wax. It works good and doesn't wash away much. It also can be used for cable lube. Previously I used Maxima chain lube (the sticky goopy stuff) and everything stuck to it. Also tried atf and it washed off in 20mins of rain . I used to own a grunge brush but I destroyed it in about 5 uses. My current regimen is to spray on some sort of de-greaser while washing my bike and spray off with a hose and wipe dry afterwards. Link to comment Share on other sites More sharing options...
guernsey70 Posted March 6, 2016 Share Posted March 6, 2016 Once a month I do this - Kerosene (paraffin here in the UK) , grunge brush, Kerosene, wipe clean with a cloth, apply Silkolene semi-synthetic chain lube - done! I also use a Grease Ninja to apply the chain lube, which is one of the best bike gadgets that I've bought so far - gets the job done in seconds, without any mess. Link to comment Share on other sites More sharing options...
kayotte Posted April 16, 2016 Share Posted April 16, 2016 My favorite is DuPont Teflon Chain Saver. Chain looks nice and clean Link to comment Share on other sites More sharing options...
filo79 Posted April 29, 2016 Share Posted April 29, 2016 I'm using an 85W90 oil for transmissions and gearboxes, like Regina Chains and DID say, i use a small brush, very little quantity of oil, with warm chain, i brush all the inside of the chain, then i leave it for all the night and the day after, i remove the extra oil with a clean towel. Only few oil drops flying around (and they are easy to clean up, oil spray it's more hard), easy to use, very very cheap (8€ for a lt of oil), it's not durable like the sticky oil spray (300-400km instead 500-600 i think) but because of its "oil" nature, it leaves the chain clean with no dirt from the road like the spray does. Link to comment Share on other sites More sharing options...
desertfjr Posted April 29, 2016 Share Posted April 29, 2016 Here's my solution... Satellite Controlled Chain Oiling Link to comment Share on other sites More sharing options...
fj09excited Posted April 29, 2016 Share Posted April 29, 2016 I use a spray can called "chain wax" used it on all of my chains, granted I have never had a bike long enough to tell if it works or not, but it seems to work just fine. The KLR chain was a little dirtier than the rest of the chains but that was because I went off road, mud, sand, 2 tracks, so I would blame that on a dirty KLR chain. The rest though, noticed nothing bad. Link to comment Share on other sites More sharing options...
Premium Member peporter Posted April 29, 2016 Premium Member Share Posted April 29, 2016 My favorite combo now is Tirox Chain Clean 360, (Amazon) that comes with a neat 360 degree brush that is O ring friendly along with an aerosol can of chain cleaner. After the chain is cleaned up and wiped off, I use a Grease Ninja and the "old" formula Teflon Multi-Use Dry, Wax Lubricant. I ride mostly paved roads and have not taken the bike out in the rain yet, so, my "every 1000 miles whether it needs it or not schedule applies. I have a Tuturo Chain oiler (thanks Richland Rich and Wessie) waiting in the wings when my supply of Dupont runs out. That won't be for a while though, because I stocked up before they discontinued the old formula. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted April 29, 2016 Premium Member Share Posted April 29, 2016 I use Maxima change guard's Synthetic chain oil Link to comment Share on other sites More sharing options...
new2me Posted April 29, 2016 Share Posted April 29, 2016 Here's my solution... Satellite Controlled Chain Oiling Looks like a well designed kit but I'm trying to understand what a chain oiler needs gps for? Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted April 29, 2016 Premium Member Share Posted April 29, 2016 Here's my solution... Satellite Controlled Chain Oiling Looks like a well designed kit but I'm trying to understand what a chain oiler needs gps for? Maybe they adjust the oil viscosity depending on where you are currently riding! Link to comment Share on other sites More sharing options...
timg Posted April 29, 2016 Share Posted April 29, 2016 Looks like a well designed kit but I'm trying to understand what a chain oiler needs gps for? Maybe they adjust the oil viscosity depending on where you are currently riding! It really couldn't change the viscosity - that's a manufactured in property of a liquid. Here is their justification: The PRO-OILER is the first and only system to give you continuous electronically metered and pumped lubrication - based on how far you have traveled. "Think about it: The only thing that matters to your chain is the distance it's covered. More distance = more oil... simple! The PRO-OILER works like this: · The microprocessor registers the actual speed and after a certain distance it sends a signal to the pump. · The precision electromagnetic pump then delivers a dose of oil to the chain - always exactly the same amount per pump stroke, regardless of temperature or oil viscosity. · You, the rider, can select the distance at which the pump fires. Your controller is mounted up front, and you see your settings and other info on the LED display. · When it rains, or in dirty conditions, you simply adjust the oil delivery as you wish with the + and - buttons... all while on the move of course!" Link to comment Share on other sites More sharing options...
