igalmarino Posted September 2, 2020 Share Posted September 2, 2020 I am having problems turning on cruise control. I'm on the road at the correct speed on 4, 5 or 6 grear. Press the cruise control button, the indicator light turn on but if I release the throttle the bike slow down (indicator still on) Anybody had a similar problem ? Link to comment Share on other sites More sharing options...
MrFritz86 Posted September 2, 2020 Share Posted September 2, 2020 If I’m not wrong you have to press the “set” button, which I think is the “-“ button as well to activate (set) the desired speed 1 You live more in five minutes going fast on a bike than other people do in all their entire life. "Marco Simoncelli" - Yamaha Tracer 900 '19 - Honda CB650R '19 Link to comment Share on other sites More sharing options...
igalmarino Posted September 2, 2020 Author Share Posted September 2, 2020 11 minutes ago, MrFritz86 said: If I’m not wrong you have to press the “set” button, which I think is the “-“ button as well to activate (set) the desired speed I will try tomorrow. Thanks ! Link to comment Share on other sites More sharing options...
Michiel900GT Posted September 2, 2020 Share Posted September 2, 2020 Definitly that. Use the Set and Resume button. 1 Link to comment Share on other sites More sharing options...
johnmark101 Posted September 2, 2020 Share Posted September 2, 2020 The yellow indicator light tells you that you have turned the cruise on. You then have to push the "set" button and it will lock in your current speed. There is nothing like spending a day riding with friends in the grip of a shared obsession. Link to comment Share on other sites More sharing options...
RandyN Posted September 2, 2020 Share Posted September 2, 2020 51 minutes ago, johnmark101 said: The yellow indicator light tells you that you have turned the cruise on. You then have to push the "set" button and it will lock in your current speed. And when you press the set button a secnd light will come on. Link to comment Share on other sites More sharing options...
Tango Posted September 2, 2020 Share Posted September 2, 2020 And then if the "Set" indicator doesn't light up check to see if your boot is touching the brake... 2 Blue Lives Matter Link to comment Share on other sites More sharing options...
WKE002 Posted September 2, 2020 Share Posted September 2, 2020 Good one Tango, at one point of time while trying to engage set, it just simply unable to lock in, off it and try again and does not work, discover after many attempt it was my heavy shoes on the brakes that is causing it unable to engage. 3 Link to comment Share on other sites More sharing options...
igalmarino Posted September 2, 2020 Author Share Posted September 2, 2020 It is working now. Thank you very much ! I need to read the manual ..... 3 1 Link to comment Share on other sites More sharing options...
nigel5 Posted September 2, 2020 Share Posted September 2, 2020 2 hours ago, igalmarino said: It is working now. Thank you very much ! I need to read the manual ..... It does help😉 Link to comment Share on other sites More sharing options...
Bonneville Posted September 3, 2020 Share Posted September 3, 2020 Never understood why cruise control needs to be turned on before set. In my Volvo V90 ON equals SET, which works excellently. Link to comment Share on other sites More sharing options...
HGP61 Posted September 3, 2020 Share Posted September 3, 2020 23 minutes ago, Bonneville said: Never understood why cruise control needs to be turned on before set Probably a safety measure you are less likely to switch on cruise control by accident if you have to press two buttons. Volvo drivers probably don't need this as they are probably very safety concious.😃 1 Link to comment Share on other sites More sharing options...
Shizzle Posted September 4, 2020 Share Posted September 4, 2020 Yep, pressing 2 button's literally wears me out wen riding 😏 1 3 Link to comment Share on other sites More sharing options...
SKYFLIX Posted September 4, 2020 Share Posted September 4, 2020 I actually like the way that Yamaha designed this. With one push and roll action, you can both turn on the system, and set your desired speed. Link to comment Share on other sites More sharing options...
Tango Posted September 4, 2020 Share Posted September 4, 2020 15 hours ago, Shizzle said: Yep, pressing 2 button's literally wears me out wen riding 😏 Well I guess if you weigh that against the energy saved using a Quick Shifter you come out ahead... 😀 😝 Blue Lives Matter Link to comment Share on other sites More sharing options...
