bugie Posted January 24, 2020 Share Posted January 24, 2020 Hey all, I am in the process of changing my oil and when removing the oil drain bolt realised i can't seem to see the gasket. Can someone please tell me if this oil drain plug is missing the gasket or not? Thanks Link to comment Share on other sites More sharing options...
HGP61 Posted January 24, 2020 Share Posted January 24, 2020 Check its not stuck itself to the sump casing seen that happen before 1 Link to comment Share on other sites More sharing options...
bugie Posted January 24, 2020 Author Share Posted January 24, 2020 There isn't anything stuck on the sump casing as it's flush. so the drain plug pic looks like it is missing the gasket right? Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted January 24, 2020 Supporting Member Share Posted January 24, 2020 @bugie The crush washer is on the drain plug. Take a small flat head screwdriver and separate it from the base of the drain plug. 1 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 24, 2020 Supporting Member Share Posted January 24, 2020 47 minutes ago, roadrash83 said: @bugie The crush washer is on the drain plug. Take a small flat head screwdriver and separate it from the base of the drain plug. Agreed. There should be a separate crush washer, usually silver. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
FJ29ER Posted January 25, 2020 Share Posted January 25, 2020 (edited) It is there. Just smooshed. Have fun getting it off. Always a pain. Usually i take a small screwdriver and pry it up a bit then take some small wire cutters and cut it off. Edited January 25, 2020 by FJ29ER Link to comment Share on other sites More sharing options...
nhchris Posted January 25, 2020 Share Posted January 25, 2020 And it is often a snug fit. I occasionally must thread my washer off the plug after lifting it with a small screwdriver. Consider using a low-profile Mazda drain plug and washer. (Yamaha washer = $4.50 USD, Mazda washer $0.75 USD!) 1 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
Premium Member keithu Posted January 25, 2020 Premium Member Share Posted January 25, 2020 1 hour ago, nhchris said: Consider using a low-profile Mazda drain plug and washer. (Yamaha washer = $4.50 USD, Mazda washer $0.75 USD!) Not that the Mazda plug and washer isn't a good idea, but $4.50 for the Yamaha washer sounds like gouging. I can't remember exactly what I pay, but the Yamaha filter and washer together costs me $16.75 from my dealer IIRC. Link to comment Share on other sites More sharing options...
bugie Posted January 25, 2020 Author Share Posted January 25, 2020 Thanks all managed to get it off. It was almost completely flat so have a sneaking suspicion the sealer may have been reusing it 1 Link to comment Share on other sites More sharing options...
nhchris Posted January 25, 2020 Share Posted January 25, 2020 There is a school of thought that believes, in a pinch, that you can flip the washer 180 deg and reuse a second time. Why a dealer would do that when he can over charge you for a new washer seems strange. 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
koth442 Posted January 25, 2020 Share Posted January 25, 2020 I only swap the little crush washer after it's been used a few times. Never an issue over 10+ bikes and 50,000 miles. 1 '15 FJ09 Link to comment Share on other sites More sharing options...
bugie Posted January 25, 2020 Author Share Posted January 25, 2020 4 hours ago, nhchris said: There is a school of thought that believes, in a pinch, that you can flip the washer 180 deg and reuse a second time. Why a dealer would do that when he can over charge you for a new washer seems strange. Well when I turned up at the dealer, he was out of stock, said none were on order and told me that they often use honda ones instead. I think there are probably 10 year old bikes here running on the original washer 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 25, 2020 Supporting Member Share Posted January 25, 2020 46 minutes ago, koth442 said: I only swap the little crush washer after it's been used a few times. Never an issue over 10+ bikes and 50,000 miles. +1 I reuse the crush washer several times. I use the low profile R1 drain plug, never had a leak. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted January 26, 2020 Premium Member Share Posted January 26, 2020 The washers are very cheap (<$1), so I buy a handful and replace them every time I change my oil. Honestly, I would feel really stupid if that ended up being what caused me to get stuck somewhere. Link to comment Share on other sites More sharing options...
nhchris Posted January 26, 2020 Share Posted January 26, 2020 Here's a weird oil story... On my most recent change I pulled the plug and let her drain away. Then I pulled the filter. Then I let the bike sit and drain for a several hours. I installed the new filter and spun the plug in temporarily until I could get a new crush washer. A few days later I had the washer and was ready to finish the job. I spun the drain plug out to install the washer and about 3 oz of oil gushed onto the floor! Where did all that oil come from? Apparently full synth takes a loooong time to drain completely. 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
