stizo Posted July 31, 2020 Share Posted July 31, 2020 Where can I order one here in the States? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 31, 2020 Supporting Member Share Posted July 31, 2020 Several members here ordered them from Europe, myself included. Even at that distance, most had delivery within a week. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted July 31, 2020 Supporting Member Share Posted July 31, 2020 1 hour ago, betoney said: A 10 lb weight savings AND smoother fueling with the flash. Win, Win! True on both counts... although I felt I lost power (felt especially in A mode) with a reflash for the slip-on. I was not going to ride w/o the baffle, or drill holes in it to fix it... so I sent it back to Dave to revert my ECU to previous flash (for OE exhaust). Bike is back to its peppy self. Was going to update my last post on this. YMMV. Link to comment Share on other sites More sharing options...
stizo Posted July 31, 2020 Share Posted July 31, 2020 1 hour ago, betoney said: Several members here ordered them from Europe, myself included. Even at that distance, most had delivery within a week. Which vendor did you order from? Scorpion directly or elsewhere? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 31, 2020 Supporting Member Share Posted July 31, 2020 6 minutes ago, stizo said: Which vendor did you order from? Scorpion directly or elsewhere? This is the vendor I ordered from but the website says "checkout is closed temporarily"??? Yamaha MT09 Tracer Scorpion Exhaust Serket Taper Slip-on - Titanium It might be easier to contact them directly. Yamaha Tracer 900 Exhausts | Tracer 900 Performance Exhausts | Scorpion Exhausts Yamaha Tracer 900 Exhausts from Scorpion Red Power. Increase the power... 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
iitywygms Posted July 31, 2020 Share Posted July 31, 2020 (edited) Demon Tweeks | Motorsport, Car Tuning & Motorcycle Parts Driven by passion, Demon Tweeks offers the most complete and innovative... Took two weeks from this vendor. Shipping was 4 days to cali. Edited July 31, 2020 by iitywygms 1 Link to comment Share on other sites More sharing options...
iitywygms Posted July 31, 2020 Share Posted July 31, 2020 14 hours ago, betoney said: This is the vendor I ordered from but the website says "checkout is closed temporarily"??? Yamaha MT09 Tracer Scorpion Exhaust Serket Taper Slip-on - Titanium I think they may be out of business. I tried contacting them several times and their fb page has nothing for about a year. Link to comment Share on other sites More sharing options...
iitywygms Posted July 31, 2020 Share Posted July 31, 2020 15 hours ago, piotrek said: True on both counts... although I felt I lost power (felt especially in A mode) with a reflash for the slip-on. I was not going to ride w/o the baffle, or drill holes in it to fix it... so I sent it back to Dave to revert my ECU to previous flash (for OE exhaust). Bike is back to its peppy self. Was going to update my last post on this. YMMV. Who flashed your ecu? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 31, 2020 Supporting Member Share Posted July 31, 2020 37 minutes ago, iitywygms said: Demon Tweeks | Motorsport, Car Tuning & Motorcycle Parts Driven by passion, Demon Tweeks offers the most complete and innovative... Took two weeks from this vendor. Shipping was 4 days to cali. @stizo - maybe check out this vendor ^^^^ 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
dpippin Posted July 31, 2020 Share Posted July 31, 2020 19 hours ago, stizo said: Where can I order one here in the States? I bought mine from MotoMachines in Virginia Scorpion Serket Taper Slip-On Exhaust Yamaha FZ-09 / MT-09 2013-2019 ... 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted July 31, 2020 Supporting Member Share Posted July 31, 2020 4 hours ago, iitywygms said: Who flashed your ecu? Vcyclenut. You will find a series of earlier posts with guys drilling out the baffle on another tuner's recommendation. I would have expected the tuner to at least ask the question, baffle in or out?... before flashing... because it apparently does make a difference. Link to comment Share on other sites More sharing options...
iitywygms Posted August 3, 2020 Share Posted August 3, 2020 It's back together and what a difference. The exhaust with the tune makes it a new bike. Literally. Jerky throttle gone. Smoother running. Just feels way better. Getting the original exhaust off was pretty easy. I was able to get it off while leaving center stand on. Getting the connector pipe lined up took the most time for me. Getting everything to line up to the mounting bracket on the can and the scorpion supplied bracket was most irritating. The scorpion bracket is at a angle and it never really sat flush with the bracket on top of the exhaust can no matter what I did. So finally I worked backwards. I mounted the can to the bracket. Then put the connector pipe on the can. Then jockey the connector pipe around to finally line up with the header. Seemed backwards but it worked. 2 2 Link to comment Share on other sites More sharing options...
jdavis Posted August 3, 2020 Share Posted August 3, 2020 I found, and a few others, that the pipe is a tad restrictive at high rpm's. I drilled a few extra holes in the baffle to fix this problem. 1 Link to comment Share on other sites More sharing options...
Willie17FJ-09 Posted August 3, 2020 Share Posted August 3, 2020 Do you get much back firing on deceleration? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 3, 2020 Supporting Member Share Posted August 3, 2020 38 minutes ago, Willie17FJ-09 said: Do you get much back firing on deceleration? On my bike I have ZERO popping or backfiring with the Scorpion. 1 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
